Results 1 to 10 of 10
    Geek Administrator ncttrnl's Avatar
    Another Recall on VW brake light switches
    Dunno why mine wasn't recalled... Damned TT has been through 3 of them now.
    http://money.cnn.com/2006/05/26/Auto...reut/index.htm
    This signature intentionally left blank.
    Bourgeoisie Moderator paultakeda's Avatar
    Venice, CA
    Re: Another Recall on VW brake light switches
    No one's touching mine. It works, it's always worked, and no recall will tell me differently.
    SoCalEuro Member cynicalgeek's Avatar
    Jan 2003
    Escondido
    Been through 2 of them here. Careful Linus, I think Murphy lurks this board...
    Optimist Moderator xoutofstepx's Avatar
    Mar 2006
    RSM
    my car has been getting stuck in park lately. damn switch messing everything up.
    2.GO Moderator EDM's Avatar
    SoCal
    I think Net has been through about 2 or 3 also.
    Venice, CA
    Let's just say this. My car has never had a problem with any of the recall issues. The windows never fell, the coolant temp sensor never failed, the coilpacks never died, and the brake light switch runs just fine.
    Granted, I changed out my temp sensor just in case, and Timmons Long Beach claims they changed the coilpacks as a preventative measure during my second to last warrantied service. But the windows, as far as I know, are still using plastic rails and the brake light switch is an original piece.
    But I do have other crap wrong with, all completely due to my tinkering; like why I can't boost past 16psi even though the ECU wants 19... it's been two years and I still don't know why. I'd rather focus this and the fact that I still need to install my 2003+ style side mirror housings with built-in blinkers after having the damned plastic pieces in my closet for almost three years. No worries, Eric, Murphy's with me, all right.
    Northwestern Ambassador Administrator madajb's Avatar
    Jun 2002
    Quote Originally Posted by Wile_E
    Never touched mine either.
    But then, I'm not often behind my car, so the entire rear lighting system could be out and I'd never know until the semi rear-ended me...
    -ajb
    Venice, CA
    Alan, wasn't yours on the fritz when you were down here?
    Quote Originally Posted by paultakeda
    He was with me when mine went out on the way to SD from an Anaheim meet.
    Jun 2002
    Nope.
    I did the window regulator thing 5 times though(in a 2 door car, you do the math).
    -ajb
