Results 1 to 7 of 7
    MISSION: WAR Forum Supporter Agent Orange's Avatar
    Palmdale
    HELP! Water in the car....
    Okay, I remember we used to do this a LOT when it was raining a lot, but I never bothered to learn how. Sunroof drains are clogged and so the water goes into the driver's side of the car. Anybody able to tell me how to clean these so it stops??? Carlos maybe? Mad rep for anybody who helps...
    I drive crap. Expensive crap...
    SoCalEuro Member Forum Supporter mike's Avatar
    Re: HELP! Water in the car....
    take an air nozzle with compressed air and blow air into the drains (lightly, you don't want to blow the hoses off) and that should take care of it. front ones are easy to get to in the corners of the sunroof cassette by the wind deflector, rear are a little harder, you got to get to them from under the car and fart the leaves up into the cassette and blow them out.
    Palmdale
    Perfect... Thanks.
    SoCalEuro Member Carlos's Avatar
    Aug 2005
    RIALTO
    you really dont want to use air because patrick is a little slow and probably will blow off the hoses. use the inside of a speedometer cable as a plumbing snake. chase the debri down with a little water.
    Palmdale
    Quote Originally Posted by glicruiz909tech View Post
    Only 5 hours later And he calls ME slow
    SoCalEuro Member Moderator URQ's Avatar
    Jun 2002
    Use a scuba tank that is about 3000 to 3700psi that will blow that hose right off.
    Oh wait you dont want to blow the hoe do you?
    Air from a compressor will work just fine...
    Aug 2005
    RIALTO
    Quote Originally Posted by 20THANNTURBO View Post
    I was busy at work today, sorry!
