n00b
easy way to do brakes?
we got a 20th anni gti and are trying to replace the rear brakes... we got these instructions... but it just aint workin...
Quick rear brake how to? 1) Jack up the car and safely support it.
2) Remove rear wheel
3) Remove rear caliper from carrier (14mm socket on ratchet and 15mm wrench)
4) Remove old pads and rotor (if rotor is stuck use a little WD40 around the lug holes and center axle cap and dont forget the retaining screw)
5) Install caliper back on carrier
6) Use special tool on speed handle to push and turn clockwise while someone keeps the caliper from being pushed inwards. If the rubber boot gets jacked up back up ½ then and go slower
7) Remove caliper and install new rotor and pads
8) Install caliper on carrier, use blue loc-tite
9) Double check the tightness of carrier bolts and rotor screw
10) Install wheel and tire with a little spark plug anti seize
11) Start car and pump brakes to remove any play in rear caliper
anyone got an easier way? we just can't seem to get off the rotor... this 30 min project has turned into 3 hours with no progress
03-22-2009 03:26 PM
# ADS
Re: easy way to do brakes?
Where is the rotor getting stuck? If the screw is removed just hit the back with a BFH to remove. You aren't reusing it so have at it.
Easiest way is to let someone who knows how to do it, do it.
If you have removed the little screw, it should come off. If its frozen, a solid smack with a hammer should break it loose. Might have to beat on it in a few spots to get it off. Its not like your going to hurt it, your replacing it.
Beat it, Michael!
Shawn Meze
02' Beetle Turbo "S" 84' Scirocco 8V (Street) 80' Scirocco "S" (Track) 99' F250 (To Tow with)
"A government big enough to give you everything you want, is big enough to take away everything you have"
Thomas Jefferson
^^^ Thank You Shawn . . . quote material!
Some people live their entire lifetime and wonder if they ever made a difference to the world.
Marines don't have that problem.
-- Ronald Reagan January 1995
Secret To Seeing What Forum Supporters See?? >>
Click Here<<
Bookmarks
