M103 R&R: Head gasket, timing chain rails, intake manifold
Results 1 to 9 of 9
    SoCalEuro Member John5788's Avatar
    Jan 2008
    Mission Viejo, CA
    went crazy with a head gasket repair job on the 190E. here are some clean pictures.
    Engine disassembled
    Cylinder head. 2 angle valve job, new intake/exhaust valve guides, new valve stem seals, hot tank, bead blast, resurface, reassemble.
    New head gasket
    Head seated on block
    New timing chain guide and tensioner rails
    Front timing cover hot tanked and bead blasted and resealed, installed
    alternator bracket hot tanked and bead blasted
    torquing down the cylinder head
    sealing top timing cover and cam seal
    valve cover bead blasted and powder coated
    John5788
    Jan 2008
    Mission Viejo, CA
    Re: M103 R&R: Head gasket, timing chain rails, intake manifold
    intake manifold hot tanked, bead blasted
    CIS installed
    Finished product
    John5788
    Jun 2008
    San Diego, Ca
    lemme know if you wanna make some extra cash. from the pics it would appear your detail oriented with your work. My M104 needs a head gasket + wiring harness job.
    SoCalEuro Member DTolo's Avatar
    Bronx, NY
    Work and final product looks great! Nice Job!
    Wherever life takes me...
    LifeByDamien.com
    SoCalEuro Member mike's Avatar
    wow John. Thats a lot of work. Good job though.
    Jan 2008
    Mission Viejo, CA
    thanks
    motor seems happy too. before the job, compression tests were reading about 165psi across cyl 1 - 3, and then gradually degraded down to 125psi in cyl 6.
    now compression readings are 180 psi across cyl 2 3 4 5, 1 and 6 read 175psi.
    John5788
    Snap-On tools ftw
    Jan 2008
    Mission Viejo, CA
    hell yeah. that tq wrench was worth the buy. very good tool to have, especially for very important high tq stuff. it has served me well with axle nuts, front crank bolt, cyl head bolts.
    John5788
    SoCalEuro n00b
    Dec 2007
    Riverside, CA.
    Man, I am starting to miss the simplicity of my m103 300e! Looking at your engine bay starts to give me a better appreciation of what these cars looked like new.
  1. Replies: 82
    Last Post: 01-11-2010, 06:46 PM
  2. 12V VR6 Timing Chain Tensioner inquiry
    By daygoVR6 in forum VW
    Last Post: 07-15-2009, 10:51 PM
  3. Replies: 1
    Last Post: 03-19-2007, 10:21 AM
  4. Replies: 2
    Last Post: 12-25-2006, 09:29 PM
  5. FF: Audi A4 1.8T exhaust manifold gasket
    By FINA4 in forum Parts and Misc
    Last Post: 10-15-2006, 07:41 PM
