+ Reply to Thread
Results 1 to 8 of 8
Thread: Turn Signal Help
    SoCalEuro n00b DirtyDubbin is an unknown quantity at this point DirtyDubbin's Avatar
    Jan 2012
    San Gabriel, CA
    Turn Signal Help
    Hey guys, so a while back i was changing out my side turn signals. I popped out the drivers side turn signal and pulled the light out of the housing but when i pulled it out, the entire light & wires pulled out. The wires were severed somewhere but i have not been able to find out where they reattach. I looked at the wiring diagram in my bentley and it said the brown wire connects to the instrument panel wiring harness. Can anyone verify that this is correct and if so how i can access it to reconnect the turn signal?
    Thanks!
    SoCalEuro Member Moderator URQ has much to be proud of URQ has much to be proud of URQ has much to be proud of URQ has much to be proud of URQ has much to be proud of URQ has much to be proud of URQ has much to be proud of URQ has much to be proud of URQ's Avatar
    Jun 2002
    Re: Turn Signal Help
    Brown is Ground.
    Jan 2012
    San Gabriel, CA
    haha my bad, other way around...
    SoCalEuro Member mitssn is a jewel in the rough mitssn is a jewel in the rough mitssn is a jewel in the rough mitssn is a jewel in the rough mitssn's Avatar
    Nov 2002
    San Marcos/Encinitas
    Tsk Tsk. That's what happens when you don't change your blinker fluid...
    Jan 2012
    San Gabriel, CA
    any ideas?
    SoCalEuro Member vdubinsd is on a distinguished road
    Mar 2007
    san clemente, ca
    1. Remove wheel and liner
    2. Find other end of harness on car-it has to be there somewhere
    3. Connect wires
    4. reinstall
    Of course i'm not going to be a pirate, i'm going to be a pirate king.
    Jan 2012
    San Gabriel, CA
    ok thanks for the tip i will try it
    Mar 2007
    san clemente, ca
    those wires you are seeking should come from the upper cowl area iirc
+ Reply to Thread
  1. MK4 Jetta - Turn signal stalk and assembly
    By IfYouSeeKay in forum Parts and Misc
    Last Post: 06-19-2009, 12:00 PM
  2. Turn signal lever loose
    By mobbin6 in forum Audi
    Last Post: 01-23-2007, 06:17 PM
  3. Turn signal change in an 02 Audi A4 ?!?
    By I <3 Audi in forum Audi
    Last Post: 01-20-2006, 11:10 AM
  4. Easy Turn Signal Question
    By Unibrium in forum VW
    Last Post: 12-29-2005, 05:50 PM
  5. WTB: Turn Signal Light
    By Stryder04 in forum Parts and Misc
    Last Post: 12-01-2005, 08:58 PM
