Installed: Water/Methanol Injection
I finally got the control unit and soleniod I needed to complete my water/methanol injection. I installed it tonight, tweaked the timing, and ran a bunch of logs with the VAG.
All I have to say is HOLY CRAP!! The car is a beast!
Basicaly I am running timing for what would be equivilent to about 98-99 octane on only 91 octane pump gas.
I dunno why more 1.8t guys don't do this. It is definetly worth the cost IMHO. I would think it's almost a must for you big turbo guys as well....
PM or IM me if you have any questions!!
Steve
09-23-2005 02:05 AM
# ADS
Originally Posted by
mitssn
Steve
You will like it alot I have been running my system for about 4 years now
Just dont run your tank dry!
Are you only using it as an intercooler sprayer or or you actually using it as an additional injection intake sprayer next to your throttle body?
topic moved to new forum
Click here to become a
Forum supporter. ||
.: WheelIndustry.com ||
Buy SoCalEuro decals here ||
stevehayes01
It is injected directly in the air stream right before the throttle body....
So how about doing a write up on the install procedure and an equipment list that you used for this project? Plus any recomendations or reference material on the best setup for the system?
_________________________________________________
Don't spread my money, spread my work ethic.
Pimpin since pimpin been pimpin!
I'm not retarded....just tarded from the get go!
doo-dee-dooo....ho-dee-humm... _____________________no slackin in my mack'n
my hand has 4 fingers....and also a thumb. _____________no slippin in my pimpin
WI is definitely a great way to fight crappy 91 california craptane. It's on my to do list. Glad you got good results with your setup.
this thread is worthless without dyno specs..............
mitssn
Steve
why would a big turbo need it as much as a the smaller K03/K04? Just think about that for a second. Most people that run a BT have a fmic, plus a BT will have a lower IAT then a K03/K04 at the same boost level.
Best thing you could do to show the diff, is to do a vag log of your IAT's without and then with the system running.
It had some power, but has MORE now.......
Ringer Racing
While KO3s start blowing hot air way sooner, I think running this, assuming what it did for Steve works for my setup, could make a massive power difference...even more of a difference than it would make on a stock turbo setup. I can't get about timing 2 on my sps3 without pulling more timing than I'd like... If I could run timing 4/5/6/7/whatever on 91 octane, I'd be psyched.
I'll have to get a ride in the car, Steve.
Car probably doesn't run.
huh?
Moderator
We had a Snow Performance kit on our old Ram diesel. It made an increase of about 60 hp, not to mention it ran very cool, even when towing about 15,000 lbs.
This was something I intended to do to the S4. Basically injecting straight into the TB, which (imho) would keep the car cool without even upgrading the IC's, not to mention the additional hp on top of the Stage III numbers!!!
I will implement a Snow system on the 20v Turbo engine once I get it a bit furhter along.
Great to hear that it is workin wel for ya. Wish i could have installed it on my car, but problems persistant, i couldn't. can't wait to get it again and try it.
wonder what it would do on an N/A car at high RPM
FOR WHOM THE FUCKING BELL TOLLS
ITS NOT WHAT YOU BUY.....ITS WHAT YOU BUILD
FunkTron
HA HA
stevehayes01
+ So what exactly did you get? The mechanical or electrical application?
"A strong body makes the mind strong. As to the species of exercises, I advise the gun. While this gives moderate exercise to the body, it gives boldness, enterprise and independence to the mind. Games played with the ball and others of that nature, are too violent for the body and stamp no character on the mind. Let your gun therefore be your constant companion of your walks." Thomas Jefferson
stevehayes01
Agreed.
Water/Methanol injection is certainly not a new idea and it is pretty cool. I think people don't know about it because it takes a little bit of knowledge to install and can cost close to the price of a chip so most people just don't spring for it. I've been seeing alot more cars running it lately though. Seems like its catching on again.
I've actually seen just the water misters. I believe New Dimensions had it... but apparently not anymore. I'm a bit sketchy on using methonal on my engine. Would that leave any unwanted deposits on my block? Or maybe shorten the life span of certain parts?
It will NOT leave any deposits--It will actually leave your engine spotless
Bookmarks
