Remove Advertisement
+ Reply to Thread
Results 1 to 11 of 11
Thread: Jason and his 855R Volvo Wagon
    vrrrrrrrrrrrooooooom Forum Supporter
    Administrator
    bugzy has much to be proud of bugzy has much to be proud of bugzy has much to be proud of bugzy has much to be proud of bugzy has much to be proud of bugzy has much to be proud of bugzy has much to be proud of bugzy has much to be proud of bugzy has much to be proud of bugzy has much to be proud of bugzy's Avatar
    The Red Wagon
    Jason Hooper and his 1997 Volvo 855R
    *CLICK ON IMAGES TO VIEW LARGER
    Words: Brad Harvey – daygoVR6, socaleuro.com
    Photos: Jared Jurgensmeier
    When car enthusiasts think wagon, performance isn’t exactly a term that follows with it. Through the mid to late 90’s Volvo took those phrases and put them together, creating a vehicle that would give driving enthusiasts something to fulfill their need for a large family sized car, while retaining the performance any true driving fan would enjoy. Jason Hooper shows us that you can take that performance to the next level with his 1997 Volvo 855R wagon.
    This is Jason’s second Volvo 855R. He originally had a ’96, but it was unfortunately totaled in an accident, after almost 2 years of searching he found what you see here just a few miles from his house no less and he started giving the car a more personal touch as soon as he got it home. Jason started out by giving the factory 2.3 liter turbo charged 5 cylinder a Dawes Devices manual boost controller and a K&N cone filter to replace the factory air cleaner. The custom fabricated 3-inch cat back exhaust system helps the engine breathe heavier though out the entire RPM range. Jason also added a Speedtuning® 17 PSI ECU to help maintain higher boost levels when the go-pedal is put to work. The ignition has been kept stock aside from the Nology® wires that are used in place of the factory originals. A carbon fiber valve cover, a factory add-on he got from the dealership, really lets the engine stand out from the rest. Since the stock internals of these cars are so strong, a Turbonetics® T3/TO4E is currently in the works, which will definitely up the power output once properly tuned.
    As Jason went through making engine tweaks, the suspension received proper modification as well to help handle the added power. Koni® adjustable shocks and struts combined with B&G lowering springs handle the bumps in the road. An OMP strut tower brace keeps chassis flex to a minimum, while the addition of VMS sway bar end-links allow for added chassis adjustments. Volvo 18-inch Pegasus wheels from a Volvo S60 fill the wheel wells and are wrapped in Nitto Neo Gen 225/40/18’s. Jason also swapped in a set of 302mm Powerslot® rotors in lieu of the factory 280mm front rotors and added stainless steel brake lines in all four corners to the mix for a better feeling brake pedal.
    The interior has been left relatively stock aside for the addition of Autometer® boost and pyrometer gauges to monitor engine vitals. The stereo has been given the tuner treatment with the addition of a Pioneer DEH-8600MP head unit combined with the XM satellite system and a Pioneer 6 disk changer. Power comes from a Diamond® 300 watt 4 channel and Alpine® amplifiers. Diamond® CM351 speakers fill the front of the cabin while Infinity® Reference 501i handle sound duties in the back. Ground shaking abilities come from a pair of 12 inch MB Quart® subs, which reside in a custom fabricated box, which sits in the back of the trunk but still allows plenty of room for trips to the grocery store.
    Jason has built himself a tuner car that any enthusiast would be proud to own, although he isn’t finished with what you see here. The future holds the addition of the larger Turbonetics® turbo, along with a Dastek® Unichip piggyback software for added tuning abilities. Jason is also looking to bolt in a 6 speed manual transmission and change out the suspension with a full coil-over set up.
    I don’t know of too many soccer moms that are looking to modify their wagons so extensively, but if you are looking to get there in a hurry Jason can show you the way.
    VEHCILE BREAKDOWN
    Owner: Jason Hooper (boostjunkie)
    Occupation: Self-employed
    Car: 1997 Volvo Wagon 855R
    Engine: Factory 2.3 Liter 5 cylinder w/factory turbo charger
    Mod List
    Engine: Speedtuning 17psi ECU, Dawes Devices manual boost controller, K&N cone, 3" exhaust, NOLOGY wires
    Transmission: Factory 4 speed auto
    Suspension: Koni adjustable shocks/struts, B&G springs, OMP strut brace, VMS sway-bar end-links
    Rollers: 18 inch Pegasus Volvo wheels on 225/40/18 Nitto Neo Gen rubber
    Exterior: Clear front turn signals, blacked out front grill
    Interior: Autometer boost and pyrometer gauges, Pioneer DEH-P8600MP with XM and 6 disc changer, Diamond CM351 speakers front, Infinty Reference 5012i in back, 2 12"MB Quart subs, Diamond 300/4 amp, and Alpine MRD-M1005 amp
    TO VIEW THE REST OF THE PHOTOS BY JARED CLICK HERE
    .: GONE 2000 BMW M5 :: Me - 2000 Jetta 1.8t :: Fiance - 2009 VW GTI :: Dad - 2002 VW JTI 337 :.
    Gone:: 1999 VW GTI VR6 :: 2002 Audi A4 Avant 1.8t :: 1989 VW GTI 16v :: 1994 Volvo 850 Turbo wagon
    Click here to become a Forum supporter. || .: sdMotorsports.com || Buy SoCalEuro decals here || sdTINT.com
  2. Remove Advertisement
    n00b WhiteT5 is on a distinguished road
    Plano, TX
    VS Represent!
    whappoost Moderator wikedgolf has much to be proud of wikedgolf has much to be proud of wikedgolf has much to be proud of wikedgolf has much to be proud of wikedgolf has much to be proud of wikedgolf has much to be proud of wikedgolf has much to be proud of wikedgolf has much to be proud of wikedgolf has much to be proud of wikedgolf has much to be proud of wikedgolf's Avatar
    victomville
    got to love the volvo!
    click here to read my MINI's Specs
    Quote Originally Posted by TOYr32
    Nice, I get to fill 2 trunks with my Junk!!! Couldn't have asked for a better Xmas present!!!
    I got some mini love in my pants . . . I'm Asian
    SoCalEuro Member Forum Supporter Brk4Euros is a jewel in the rough Brk4Euros is a jewel in the rough Brk4Euros is a jewel in the rough Brk4Euros's Avatar
    Apr 2004
    Sweet wagon! Paint looks awesome too!
    Mrs. Budd Forum Supporter
    Moderator
    netnet is a glorious beacon of light netnet is a glorious beacon of light netnet is a glorious beacon of light netnet is a glorious beacon of light netnet is a glorious beacon of light netnet's Avatar
    Eric and I have seen this Ride in Esco
    Hella Fast!
    SoCalEuro Member Doug242ti will become famous soon enough
    Jan 2004
    Norcal and movin up
    Sweet congrats Jason!!!
    damn now I really need to put the yellow back together. :lol:
    SoCalEuro Member g60racer will become famous soon enough g60racer will become famous soon enough g60racer's Avatar
    Feb 2003
    that is actually one of my dream cars. Nicely done up!!!
    Brendan Prout
    2004 R32 Golf 90k miles
    1990 RSR Corrado 303k miles!!!!!
    1973 Fiat Spider 22k miles
    Administrator
    Quote Originally Posted by g60racer
    me too
    SoCalEuro Member SoCal_GLI is a name known to all SoCal_GLI is a name known to all SoCal_GLI is a name known to all SoCal_GLI is a name known to all SoCal_GLI is a name known to all SoCal_GLI is a name known to all SoCal_GLI's Avatar
    Escondido
    holy Rob VanWinkle
    ive never seen it, but i love it
    2.GO Moderator EDM has much to be proud of EDM has much to be proud of EDM has much to be proud of EDM has much to be proud of EDM has much to be proud of EDM has much to be proud of EDM has much to be proud of EDM has much to be proud of EDM has much to be proud of EDM's Avatar
    SoCal
    Yes that thing is pretty fast. Looks good too.
    SoCalEuro Member stevehayes01 will become famous soon enough stevehayes01 will become famous soon enough stevehayes01's Avatar
    Nov 2004
    San Pedro, Ca
    That is such a sweet ride!!
    Steve H.
    2000 SAAB 9-3 SE H.O.T.
    Tuned by Hayes Performance Products
+ Reply to Thread
